vcProgram
Program is an executable program that can be run by executor objects. Every executor, by default, has its own a built-in program.
Module: vcExecutor
Referenced by: vcRobotExecutor.Program, vcViewAnimation.Program
MainRoutinevcRoutineRGets the main routine of the program.
NameStringRWGets or sets the name of the program.
PropertiesvcPropertyContainerRGets the properties of this program.
RoutinesvcObservableList[vcRoutine]RGets a list of all routines in the program other than the main routine.
createRoutinevcRoutineString nameCreates a new routine of a given name in the program.
name (String): Routine's name.
vcRoutine: the new routine.
ValueError: When given routine name is empty or not unique.
findRoutinevcRoutineString nameFinds a routine matching a given name in the program.
vcRoutine: The found routine. None if no routine was found.
NameParametersDescription
OnStatementAddedvcStatement statementTriggered when a statement is added to the program.
statement (vcStatement): The added statement.
OnStatementRemovingvcStatement statementTriggered when a statement is removed from the program.
statement (vcStatement): The removed statement.
